Huawei Mate 9 Rear and Front Camera Replacement
Выберете то, что вам нужно
  1. Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: шаг 1, изображение 1 из 3 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: шаг 1, изображение 2 из 3 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: шаг 1, изображение 3 из 3
    • Turn off your Huawei Mate 9 smartphone and remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Huawei Mate 9 Rear and Front Camera Replacement: шаг 2, изображение 1 из 3 Huawei Mate 9 Rear and Front Camera Replacement: шаг 2, изображение 2 из 3 Huawei Mate 9 Rear and Front Camera Replacement: шаг 2, изображение 3 из 3
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Huawei Mate 9 Rear and Front Camera Replacement: шаг 3, изображение 1 из 2 Huawei Mate 9 Rear and Front Camera Replacement: шаг 3, изображение 2 из 2
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  4. Huawei Mate 9 Rear and Front Camera Replacement: шаг 4, изображение 1 из 2 Huawei Mate 9 Rear and Front Camera Replacement: шаг 4, изображение 2 из 2
    • Using a spudger, disconnect the battery connector.
    • After disconnecting the battery connector, you can now completely remove the back cover.
  5. Huawei Mate 9 Rear and Front Camera Replacement: шаг 5, изображение 1 из 3 Huawei Mate 9 Rear and Front Camera Replacement: шаг 5, изображение 2 из 3 Huawei Mate 9 Rear and Front Camera Replacement: шаг 5, изображение 3 из 3
    • Use a Philips 000 screwdriver to remove the two 1.0 mm Philips #1 screws securing the metal plate.
    • After removing the metal plate, you can now remove and replace the rear camera from its slot.
  6. Huawei Mate 9 Rear and Front Camera Replacement: шаг 6, изображение 1 из 2 Huawei Mate 9 Rear and Front Camera Replacement: шаг 6, изображение 2 из 2
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
Заключение
2 участников успешно повторили данное руководство.
Rogelio Ramirez
Участник с: 06/25/17
524 Репутация
Автор 3 руководств
Команда
UC Davis, Team S7-G8, Lore Fall 2018 Участник UC Davis, Team S7-G8, Lore Fall 2018
UCD-LORE-F18S7G8
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 2,111
