Введение
If your Huawei MultiPad M3 (model 9599773) is not providing sufficient battery life or taking too long to charge, use this guide to replace the battery in the tablet. Before deciding to replace the battery, inspect the charging chord for damage or a short in the wiring causing the device not to charge properly. Typically, a new chord will give the device sufficient battery life.
Before beginning make sure to power off your phone completely and disconnect from any external power.
Выберете то, что вам нужно
Using the tweezer tool, remove the ribbon cable attached to the main display in two places.
Using the Jimmy, break the adhesive that holds the battery to the main body and remove the battery from the device.
7 участников успешно повторили данное руководство.
