Введение
This guide is about how to replace the front camera of Huawei MediaPad M3. A prerequisite of this guide is removing the display. Please see the “Display assembly” guide. The front cameral has 8-mega pixels without a front flash light. The camera is a relatively small part; please store it in a proper place.
Выберете то, что вам нужно
Use a heat gun to heat the display. It may take up to 30 seconds.
Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
Open the display carefully.
Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
After removing the two screws, use your hand to take out the silver metal bracket.
