Введение
This guide is about how to replace the motherboard of Huawei MediaPad M3. A prerequisite of this guide is removing the display. The motherboard requires the removal of multiple screws; please store screws carefully for reassembly.
Выберете то, что вам нужно
Use a heat gun to heat the display. It may take up to 30 seconds.
Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
Open the display carefully.
Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
After removing the two screws, use your hand to take out the silver metal bracket.
Use a Phillips #00 screwdriver to remove this 3mm screw.
Remove the small silver metal bracket.
First, remove the right ribbon cable from the board.
Next, remove the left ribbon cable from the board.
Use a Phillips #00 screwdriver to remove the 3mm screw present on top of the silver metal bracket.
Remove the silver metal bracket from the board.
Remove the yellow ribbon cable using a plastic opening tool.
Use a Phillips #00 screwdriver to remove the two 3mm screws.
Remove the black plastic cover from the board.
Carefully remove the motherboard from the device by using a plastic opening tool.
4 человек успешно провели ремонт по этому руководству.
