Введение
This guide is about how to replace the back camera of Huawei MediaPad M3. A prerequisite of this guide is removing the display. Please see the “Display assembly” guide. Rear camera has 8-mega pixels with a flashlight. Screws and the camera itself are relatively small; please store them carefully for reassembly.
Выберете то, что вам нужно
Use a heat gun to heat the display. It may take up to 30 seconds.
Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
Open the display carefully.
Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
After removing the two screws, use your hand to take out the silver metal bracket.
