Введение
Use this guide to replace the charging board in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
  1. Switch off your phone. Remove the two Pentalobe P2 screws at the bottom. Remove the SIM card tray.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. Getting the prying tool in  will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover. Swing open the phone backwards.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Remove the Phillips #00 screw. Use tweezers to remove the metal plate. Use a spudger to disconnect the battery flex cable.
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Remove the four Phillips #00 screws. Use Tweezers to remove the metal plate.
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  6. Use a spudger to disconnect the main flex cable. Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  7. Use a spudger to disconnect the headphone jack and the loudspeaker flex cables. Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  8. Do not damage any components sitting on the charging board while removing it. Use a spudger to pry out the charging board.
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
Заключение
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
12 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 23.11.2016
102 714 Репутация
Автор 413 руководств
Команда
iFixit Участник iFixit
Community
140 членов
Автор 15 637 руководств
Комментариев: 3
Just remember to take off a tape from the microphone on a new piece. I had to open mine twice
Michal Kornacki - Ответить
If you have problems on connecting the cable to the charging port, before considering replacing the charging board, try removing the dust that may be occluding the port. Use tweezers to remove the dust and try if the cable connects. Do it carefully as your could damage the pins.
Gerard Encina Llamas - Ответить
Second the above comment! - If you are having trouble fully inserting the USB cable, then try remove the dust with a pair of fine tweezers.
Andrew Norwood - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 20
За последние 30 дней: 82
За всё время: 4,884
