Введение
Use this guide to replace the front facing camera in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
Выберете то, что вам нужно
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
Flip the rear cover over to the right side of the phone.
Use a pair of tweezers to remove the sticker.
Remove the two Phillips #00 screws.
Remove the four 2.5 mm Phillips #00 screws.
Use tweezers to remove the mainboard shield.
Use the flat end of a spudger to disconnect the finger print sensor flex cable.
Remove the three Phillips #000 screws.
Use tweezers to remove the two metal shields which cover the flex cables on the mainboard.
Use the flat end of a spudger to disconnect the volume and power button, the display and the main flex cable.
Disconnect the battery flex cable with a spudger.
Unplug the antenna cable with tweezers.
Disconnect the headphone jack flex cable with the flat end of a spudger.
Use an opening pick to pry out the motherboard until you can get a good grip.
Remove the motherboard.
Disconnect the flex cable of the front facing camera with a spudger.
Flip the motherboard and grab the front facing camera with tweezers. Thread the flex cable through the gap in the motherboard.
Remove the front facing camera.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Еще один человек закончил это руководство.
