  1. Turn the phone off and remove the SIM Tray before beginning the repair
    • Turn the phone off and remove the SIM Tray before beginning the repair
  2. Use a suction cup and pick to get between the battery cover and frame. Work the pick all the way around to loosen the adhesive and remove the cover.
    • Use a suction cup and pick to get between the battery cover and frame.
    • Work the pick all the way around to loosen the adhesive and remove the cover.
    • Flip the cover carefully to the right side of the phone, there is a cable attached to the back cover for the fingerprint ID sensor.
  3. Release the ZIF connector to remove the Fingerprint scanner cable from the back cover.
    • Release the ZIF connector to remove the Fingerprint scanner cable from the back cover.
    It will be easier to put it back if releasing by the other side of the flex cable which is under the metallic cover of usb charging board, fingerprint reader and battery connector and fixed with two screws (metallic plate above the black flex cable)
    Miguel Cretu - Ответить
  4. Remove the 8 upper screws that hold the metal covers.
    • Remove the 8 upper screws that hold the metal covers.
    • One of the screws may be covered with a white dot sticker. Remove the dot to access the screw.
    The motherboard is also fixed to the frame with clips. Pull it by the right side. It also hase thermal paste which could act as a sticking solution. I cleaned the one which remains on the motherboard and added another new which is being used on computers
  5. Once the screws have been removed (as described in the previous step) the two lower metal covers can be removed. The upper cover can be removed by prying the upper right corner free (2nd picture).
    • Once the screws have been removed (as described in the previous step) the two lower metal covers can be removed.
    • The upper cover can be removed by prying the upper right corner free (2nd picture).
  6. On the left side in the frame, is a small plastic retainer. Remove this and transfer to the new frame.
    • On the left side in the frame, is a small plastic retainer. Remove this and transfer to the new frame.
    Don’t forget to remove the button flex if it’s not on the new frame
    Karim Chakroun - Ответить
    Attention: The flex with the buttons is well sticked to the frame. Take care how you are removing it. Use a thin tool and try to release the stick with a caution to don’t damage the flex. Pull slowly the flex.
    If you breake it, you won’t be able to turn on the phone
  7. Disconnect the battery connector from the mainboard.
    • Disconnect the battery connector from the mainboard.
    • Remove the dual camera, the front camera and the two flex cables. The Wi-Fi antenna cable can also be disconnected
    If you wont put a new battery, take care how you unstick the original / old one. It’s too well glued. Heat it well by the screen side using the iOpener or simial gel back pre-heated in the MWO. Use some plastic flat too to breake the glue. The battery will get deformed. I straghted it back and it seems to keep working.
    My new frame came with this glue new and covered with a plastic. I didn’t removed that plastic in case the battery is damaged while taking out and it has to be replaced.
  8. Using a spudger, carefully pry the mainboard up on the upper right corner to release it from the frame.
    • Using a spudger, carefully pry the mainboard up on the upper right corner to release it from the frame.
    Remove also the earpiece and the proximity sensor (you need to remove the old screen for that)
  9. At the bottom of the phone, there are seven screws that need to be removed.
    • At the bottom of the phone, there are seven screws that need to be removed.
    • Underneath the cover is the daughterboard
  10. Using the iOpener or a similar tool, loosen the cover on the right side, by prying between the cover and the frame. At the top of the cover (2nd picture) use the iOpener to pry up the cover to remove it from the frame. Underneath the cover is the daughter board containing the charger port and headphone jack. Disconnect the cable attached to the daughter board.
    • Using the iOpener or a similar tool, loosen the cover on the right side, by prying between the cover and the frame.
    • At the top of the cover (2nd picture) use the iOpener to pry up the cover to remove it from the frame.
    • Underneath the cover is the daughter board containing the charger port and headphone jack. Disconnect the cable attached to the daughter board.
    • Pry the daughter board to remove it from the frame, it is lightly glued, and can be reused in the new frame.
    • Repeat the steps in reverse to reassemble the phone.
Заключение
15 участников успешно повторили данное руководство.
Harvey
Участник с: 15.02.2016
2 688 Репутация
Автор 6 руководств
Комментариев: 16
Can the antenna cable (black thin one) be reused?
Edvin Mattsson - Ответить
Yes, all the cables that are removable can be reused.
Harvey - Ответить
hi, when you replace a faulty battery does the screen needs to be changed as well even though the screen is fine?
fundiswamkutyukelwa - Ответить
Normally if you can remove the battery, without damaging the screen then just replacing the battery should be ok
Harvey -
I had to replace the back cover as well as it was also damaged. You will have to try it and see if the adhesive is still strong enough to stick.
Harvey -
Can the back cover be reused with the adhesive that's on it if heated?
Heinrich Von Schnitzel - Ответить
Hard to say, you would have to see if it is still strong enough.
Harvey -
Can I still get the old battery which is functioning well
haizekibar - Ответить
Normally if the battery can be removed withou damage then it can be reused.
Harvey -
Hi.. I changed my huawei p20 lite screen with a replica and now the finger print option disappeared ?????
Kesigan Sabapathy - Ответить
Hi, it could be that the cable is not properly seated or was damaged. Is it possible to try another fingerprint cable/pad?
Harvey -
Hi all,
I broken back cover glass of my P20 lite. I was thinking to repair it by my self but I saw some video tutorial in which there’s need of Heat Gun. In this guide only suction cup is used. Could you please help me to understand if the Heat Gun is really necessary or not?
Thank you
fedemena - Ответить
Hi, you can use a heat gun or hair dryer to heat up the adhesive when removing the back cover. The purpose of heating it up is to make the removal easier and reduces the chance that the back cover will break when removing it.
Harvey - Ответить
The guide is incomplete as some important steps aren’t well explained or they weren’t even explained. In general, the guide is good
Thanks to the autor
Hi, if you have accidently jumped into a swimming pool with your Huawei P20 Lite; and the phone is still working, however you cannot enter anything using the display; i.e. when asking you to slide to unlock; the screen does nothing; and now the screen seems to have reduced the brightness down to nothing; is there anyway of fixing this?
I believe that other than this issue; the phone was still working; calls had been received (although now I have removed the sim and memory card). All data appears to be still there too
Any thoughts/suggestions are appreciated; phone went in water Weds morning (24th July)
brian-howlett - Ответить
One thing you can try is opening the phone and checking the mainboard and display connectors - it is possible that water got inside and has corroded it either on the display cable or on the mainboard side. I would recommend cleaning (or soaking) the mainboard and display connector with Iso-propynol to remove other possible corrosion or debris, put it back together and see if the touch function works. If the corrosion is on the mainboard then it may be the damage is already too extensive. If it’s on the display side, then you may get lucky by changing the display.
Hope that helps….
Harvey - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 46
За 7 дней: 460
За 30 дней: 1,784
За всё время: 17,568
