Huawei P20 Pro Rear Glass Replacement
Выберете то, что вам нужно
  1. Huawei P20 Pro Rear Glass Replacement, Rear Glass Replacement: шаг 1, изображение 1 из 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    Ich hatte keinen iOpener. Daher hab ich das P20 Pro für ein paar Minuten auf eine Wärmflasche gelegt. Die Klebeschicht konnte relativ schnell gelöst werden.
    David T. - Ответить
  2. Huawei P20 Pro Rear Glass Replacement: шаг 2, изображение 1 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 2, изображение 2 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 2, изображение 3 из 3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
    if the back cover is not broken, i’d suggest NOT to use an opening pick as if the phone was not heated enough, you may crack the glass on the edges. better use the iPlastix, it is thinner and less stressful for the glass.
    Stefano Restuccia - Ответить
    It is better to put a peak on the side because the side opens first than the bottom of the phone.
    이정일 - Ответить
    I have to agree that is is much easier to start opening from the side. Do read the rest of the guide though, to make sure you won’t hit something when opening it from the side.
    Jacob Cain - Ответить
  3. Huawei P20 Pro Rear Glass Replacement: шаг 3, изображение 1 из 2 Huawei P20 Pro Rear Glass Replacement: шаг 3, изображение 2 из 2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Rear Glass Replacement: шаг 4, изображение 1 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 4, изображение 2 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 4, изображение 3 из 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Rear Glass Replacement: шаг 5, изображение 1 из 2 Huawei P20 Pro Rear Glass Replacement: шаг 5, изображение 2 из 2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Rear Glass Replacement: шаг 6, изображение 1 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 6, изображение 2 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 6, изображение 3 из 3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Rear Glass Replacement: шаг 7, изображение 1 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 7, изображение 2 из 3 Huawei P20 Pro Rear Glass Replacement: шаг 7, изображение 3 из 3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Rear Glass Replacement: шаг 8, изображение 1 из 2 Huawei P20 Pro Rear Glass Replacement: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Rear Glass Replacement: шаг 9, изображение 1 из 2 Huawei P20 Pro Rear Glass Replacement: шаг 9, изображение 2 из 2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    Das mit den Klebstreifen funktioniert nicht. Ich habe die Tube E6000 in die Dichtungen eingeklebt und so das Smartphone wieder zusammengesetzt.
    yellowlonghair ylh - Ответить
Заключение
After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
18 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
203 160 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 767 руководств
7 Комментариев
Do you suggest any particular kind of adhesive? I always have trouble with these things. Sooner or later, if not immediately, any glass or screen I fit this way always lifts up. The adhesives that come with the parts always seem weak. I try B-7000 glue or/and double sided tape, but still it won’t sit tight.
Smeargle - Ответить
Hi Smeargle, the options you already tried are also the ones I’d recommend. When applying new double-sided adhesive I’d also suggest slightly heating the glued area and applying some pressure for a few hours (stack of heavy books overnight might do).
Tobias Isakeit -
Hey how do you get the huawei sealed back?
For it to be waterproof again.
Léo Zakri - Ответить
You either buy a rear glass with seal attached or buy a seal and do it yourself, not sure why the author didn't go over this…
jasro -
Although I understand the steps, why did you not include steps to install the fresh rear glass?
jasro - Ответить
While removing the back panel I ripped the flex cable near the speaker, the phone seems to work fine. Does anyone know what it's for?
Andy Shen - Ответить
The guide completely misses out the removal and refitting of the proximity sensor from the rear glass. There's a good You Tube video at you tube dot com / watch?v=LpwzK02HQaI
Mark Lees - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 32
За последние 30 дней: 148
За всё время: 38,489
