Huawei P20 Pro Screen Replacement
Выберете то, что вам нужно
  1. Huawei P20 Pro Screen Replacement, Rear Glass Replacement: шаг 1, изображение 1 из 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Huawei P20 Pro Screen Replacement: шаг 2, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 2, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 2, изображение 3 из 3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  3. Huawei P20 Pro Screen Replacement: шаг 3, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 3, изображение 2 из 2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Screen Replacement: шаг 4, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 4, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 4, изображение 3 из 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Screen Replacement: шаг 5, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 5, изображение 2 из 2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Screen Replacement: шаг 6, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 6, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 6, изображение 3 из 3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Screen Replacement: шаг 7, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 7, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 7, изображение 3 из 3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Screen Replacement: шаг 8, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Screen Replacement: шаг 9, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 9, изображение 2 из 2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  10. Huawei P20 Pro Screen Replacement, Motherboard Cover and NFC: шаг 10, изображение 1 из 1
    • Remove the nine Phillips #00 screws (3.4 mm length).
  11. Huawei P20 Pro Screen Replacement: шаг 11, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 11, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 11, изображение 3 из 3
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
  12. Huawei P20 Pro Screen Replacement: шаг 12, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 12, изображение 2 из 2
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
  13. Huawei P20 Pro Screen Replacement: шаг 13, изображение 1 из 1
    • Remove the motherboard cover.
  14. Huawei P20 Pro Screen Replacement, Battery Disconnect: шаг 14, изображение 1 из 2 Huawei P20 Pro Screen Replacement, Battery Disconnect: шаг 14, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  15. Huawei P20 Pro Screen Replacement, Interconnect Cable with Charging Port: шаг 15, изображение 1 из 1
    • Remove the five Phillips #00 screws (3.4 mm length).
  16. Huawei P20 Pro Screen Replacement: шаг 16, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 16, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 16, изображение 3 из 3
    • Use a pair of tweezers to disconnect the antenna cable.
    • Use a pair of tweezers to pull the antenna cable out of its routing.
  17. Huawei P20 Pro Screen Replacement: шаг 17, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 17, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 17, изображение 3 из 3
    • Slide an opening pick under the left side of the daughterboard cover and start to pry it up until you can get a good grip.
    • Remove the daughterboard cover.
  18. Huawei P20 Pro Screen Replacement: шаг 18, изображение 1 из 1
    • Remove the two Phillips #00 screws (3.4 mm length) on both sides of the USB C port.
  19. Huawei P20 Pro Screen Replacement: шаг 19, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 19, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the upper end of the interconnect and charging port flex cable from the motherboard.
  20. Huawei P20 Pro Screen Replacement: шаг 20, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 20, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 20, изображение 3 из 3
    • Use the flat end of a spudger to pry up and disconnect the bottom end of the interconnect and charging port flex cable from the daughterboard.
    • Use a pair of tweezers to move the antenna cable out of the way.
  21. Huawei P20 Pro Screen Replacement: шаг 21, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 21, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 21, изображение 3 из 3
    • Use a pair of tweezers to pull the charging port out of its recess.
    • Remove the interconnect cable including the charging port.
  22. Huawei P20 Pro Screen Replacement, Battery: шаг 22, изображение 1 из 3 Huawei P20 Pro Screen Replacement, Battery: шаг 22, изображение 2 из 3 Huawei P20 Pro Screen Replacement, Battery: шаг 22, изображение 3 из 3
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the display for at least two minutes.
    • In the following step, only apply the spudger in the areas marked in red, which is where the battery adhesive is located.
    • Avoid the orange area where the display flex cable is running.
  23. Huawei P20 Pro Screen Replacement: шаг 23, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 23, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 23, изображение 3 из 3
    • In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top left corner of the battery and start to pry it up.
    • Work your way down the left side of the battery and loosen the adhesive with the spudger.
  24. Huawei P20 Pro Screen Replacement: шаг 24, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 24, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 24, изображение 3 из 3
    • Insert the spudger at the top right corner of the battery and start to pry it up.
    • Work your way down to the bottom end of the battery to loosen all the adhesive.
  25. Huawei P20 Pro Screen Replacement: шаг 25, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 25, изображение 2 из 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
  26. Huawei P20 Pro Screen Replacement, Screen: шаг 26, изображение 1 из 2 Huawei P20 Pro Screen Replacement, Screen: шаг 26, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable at the bottom left of the motherboard.
  27. Huawei P20 Pro Screen Replacement: шаг 27, изображение 1 из 1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough on all sides. Follow the iOpener instructions to avoid overheating.
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  28. Huawei P20 Pro Screen Replacement: шаг 28, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 28, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 28, изображение 3 из 3
    • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
    • Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the plastic bezel. Start to cut the adhesive by sliding the opening pick to the top left corner.
    • Make sure you get in the right gap between the display and the plastic bezel. Do not pry between the bezel and the midframe.
  29. Huawei P20 Pro Screen Replacement: шаг 29, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 29, изображение 2 из 2
    • Insert a second opening pick and slide it to the top right corner of the phone.
    • Leave the picks in their places to prevent the adhesive from resealing.
  30. Huawei P20 Pro Screen Replacement: шаг 30, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 30, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 30, изображение 3 из 3
    • Insert a third opening pick at the top right corner of the phone.
    • Slide the opening pick down to the bottom right corner to cut all the adhesive. Leave it at the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  31. Huawei P20 Pro Screen Replacement: шаг 31, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 31, изображение 2 из 2
    • Insert a fourth opening pick at the bottom right corner.
    • Only slide the tip of the opening pick along the bottom edge of the phone to not damage the home button.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  32. Huawei P20 Pro Screen Replacement: шаг 32, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 32, изображение 2 из 2
    • Insert a fifth opening pick and slide it along the left edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and adhered on the opposite side.
  33. Huawei P20 Pro Screen Replacement: шаг 33, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 33, изображение 2 из 2
    • Use a pair of tweezers to peel the display flex cable free from the frame.
    • Thread the display flex cable through the gap in the frame and remove the display.
  34. Huawei P20 Pro Screen Replacement, Home button including the fingerprint sensor: шаг 34, изображение 1 из 2 Huawei P20 Pro Screen Replacement, Home button including the fingerprint sensor: шаг 34, изображение 2 из 2
    • Use an opening pick to open the black flap of the home button ZIF connector.
  35. Huawei P20 Pro Screen Replacement: шаг 35, изображение 1 из 2 Huawei P20 Pro Screen Replacement: шаг 35, изображение 2 из 2
    • Use a pair of tweezers to gently pull the home button flex cable out of its ZIF connector.
  36. Huawei P20 Pro Screen Replacement: шаг 36, изображение 1 из 1
  37. Huawei P20 Pro Screen Replacement: шаг 37, изображение 1 из 3 Huawei P20 Pro Screen Replacement: шаг 37, изображение 2 из 3 Huawei P20 Pro Screen Replacement: шаг 37, изображение 3 из 3
    • Apply a spudger to the backside of the home button and push it out towards the front until it comes off the screen.
    • Carefully grab the home button and thread its flex cable through the gap in the screen.
    • Remove the home button.
    • Before installing a new display, it's important to remove all traces of the old adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
Заключение
The best way to secure the new screen is with adhesive glue. Apply the glue to the plastic frame, then carefully feed the display cable through its gap, align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
40 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
202 758 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 732 руководств
11 Комментариев
Most detailed guide I’ve personally seen. And I love the detailed gif like steps, which are positively the best way to explain something. Hands down. Love it. Only the important stuff without the fluff easily accessible for back and forth.
Can’t stress enough how much I want you to keep using this formula.
*Throws happiness at screen* Here you go man
Ion Ion - Ответить
I need some help - I have the new LCD but it’s already in its housing. I am confused how to transfer all the existing parts (cameras, boards etc) onto the new frame! CL
Cameron Lawther - Ответить
Bonjour,
L’introduction du tuto stipule : “Ouvrir le Huawei P20 Pro endommagera les joints étanches de l'appareil. Si vous ne les remplacez pas, votre téléphone continuera à fonctionner normalement, mais ne sera plus étanche à l'eau. “
Comment remplacer ces joints ? Un produit en particulier ? Est-ce la colle qui fait office de joint étanche ?
Merci pour les infos,
Aurélien C - Ответить
ma compagne a cassé son p20 pro.On annoncait 340 € à réparer.Je trouvais ca beaucoup, mais avec la pièce à 220 €, et 1 à 3h de travail, ca s’explique…+ le cout des outils …Il se trouve à 300 € en 2e main ou fin de série….Mais si on est bricoleur, ca peut etre drole. Courage, et merci pour ce tuto !
gilou gilou - Ответить
Hello
I have a question.
We done everthing like it is explained. (Thank you for the amazing instruction!)
But now we want to instal the new lcd screen but there is no fixation for the home button (silver thing). And we can remove the old one. Any suggestions?
Illyris Van Der Meer - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 18
За последние 7 дней: 150
За последние 30 дней: 679
За всё время: 99,656
