Введение
Use this guide to remove or replace the charging port and main flex cable assembly in the Huawei P30 Pro.
Opening the Huawei P30 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
If the adhesive becomes hard to cut, it most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
Lift and remove the back cover.
Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Remove the ten Phillips #00 screws (4.3 mm length).
Slide an opening pick under the black adhesive at the bottom right of the charging coil.
Carefully loosen the adhesive with the opening pick.
Slide an opening pick under the black adhesive at the bottom left of the charging coil.
Slide an opening pick under the left side of the motherboard cover.
Unhinge the left side of the motherboard cover by slightly rotating the opening pick.
Push the motherboard cover out of the sockets at the top edge of the phone beginning with the top left corner.
Remove the motherboard cover including the NFC and charging coil.
Use a spudger to pry up and disconnect the battery connector.
Slide an opening pick under the top edge of the daughterboard cover.
Pry up and unhinge the daughterboard cover by slightly rotating the opening pick.
Use a spudger to pry up and disconnect the left main flex cable connector from the motherboard.
Use a spudger to pry up and disconnect the right main flex cable connector from the motherboard.
Use a spudger to pry up and disconnect the main flex cable connector from the daughterboard.
Remove the main flex cable including the charging port by lifting it upwards and then pulling it in the direction of the motherboard.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
7 участников успешно повторили данное руководство.
6 Комментариев
Hello.
I try to change my loudspeaker but wifi signal (if i’m correct about the name) cable is different.
For my phone is that small white cable and i can find only some other kind of cable.
Any idea?
Mir ist der Stecker auf der Hauptplatine (Schritt 17) kaput gegangen, was kann ich tun?
Nun kann man aber die USB-Buchse plus Haoutflachbandkabel in "Version A" und in "Version D" bestellen. Lässt sich irgendwie vorher herausfinden, welche Version man braucht? Also bevor das Telefon aufgeschraubt vor einem liegt und da dann liegenbleiben muss bis das Ersatzteil da ist?
Besten Dank.
Hallo, habe gerade dieselbe Frage. Schon was herausgefunden? Meine Vermutung liegt bei unterschiedlichen Märkten, dass z.B. Europa eine Version benutzt und eine andere Region dementsprechend die Andere, aber das ist natürlich nur eine Behauptung.
Besten Dank
