Введение
Use this guide to replace the front camera in your Huawei P8.
Выберете то, что вам нужно
First switch off your phone.
Remove the trays for the SD card and the SIM card.
Unscrew the two Torx T2 screws located at the bottom next to the device's micro USB port.
Use an iSclack or a suction handle to separate the display unit from the rear panel.
Remove the Phillips #00 screw that holds down the metal clamp covering the front camera connector.
Remove the metal clamp covering the flex connector of the front camera.
Unplug the headphone jack and the front camera flex connectors.
Remove the front camera.
6 участников успешно повторили данное руководство.
