Введение
This guide will help you replace the battery inside your Huawei P8 Lite phone.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$9.99
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
Continue by removing the SIM and SD card trays on the side of the device.
Remove the two Torx T5 screws. One may be cover with a liquid indicator.
Remove the five Phillips #000 screws.
Take away both securing brackets covering the motherboard.
Carefully separate the four connectors holding the motherboard in place.
Remove the motherboard from the device.
Locate the adhesive strip underneath the battery. Gently pull on the strip to loosen it enough to remove the battery from the device.
2 участников успешно повторили данное руководство.
