Введение
Use this guide to replace the vibrator in your Huawei P8 Lite.
Выберете то, что вам нужно
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
When all clips are open, remove the back cover from the rest of the phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
Then remove the top cover.
Remove the SIM card and SD card trays.
Disconnect the three plug connectors and one ZIF connector.
Remove the volume and power button cable.
Take out the motherboard by lifting the bottom part first.
Еще один человек закончил это руководство.
Один комментарий
Doğrusu Güzel Anlatılmış Ve Ben Her Zaman Elektronık Tüm Parçalarda KEndi İşimi Kendım Yaparım Araba Bır Ütü Belkı Bir Mekanık Parça Bu Seferde Titreşim Motorumu Deyiştirmek İstedim Ve Bu Resimler Sayesınde Kötü tornavaıdalarla Bile yarım saatte İşlem Tamam Teşekkur Edıyorum Emegi Geçipte Burada Bunu Paylaşan Herkesten
