Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
Loosen the seven Phillips #00 screws on the motherboard.
Unplug the antenna cable.
The metal plate covering the battery connector has two little hooks on each side. Use a tweezer to free them and unhinge the plate towards the top.
Now you can lift out the motherboard to access the earpiece speaker.
The earpiece speaker ist fixed with an adhesive foam gasket.
