Введение
Use this guide to replace the headphone jack in your Huawei P9 smartphone.
Инструменты
Запчасти
Детали не указаны.
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
Remove the water indicator on top of the screw.
Undo the two Phillips #00 screws.
Remove metal bracket (mind the adhesive underneath).
3 участников успешно повторили данное руководство.
