Huawei P9 Headphone Jack Replacement
Выберете то, что вам нужно
  1. Huawei P9 Headphone Jack Replacement, Back Cover: шаг 1, изображение 1 из 3 Huawei P9 Headphone Jack Replacement, Back Cover: шаг 1, изображение 2 из 3 Huawei P9 Headphone Jack Replacement, Back Cover: шаг 1, изображение 3 из 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Headphone Jack Replacement: шаг 2, изображение 1 из 2 Huawei P9 Headphone Jack Replacement: шаг 2, изображение 2 из 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Headphone Jack Replacement, Fingerprint sensor: шаг 3, изображение 1 из 2 Huawei P9 Headphone Jack Replacement, Fingerprint sensor: шаг 3, изображение 2 из 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Headphone Jack Replacement, Headphone Jack: шаг 4, изображение 1 из 3 Huawei P9 Headphone Jack Replacement, Headphone Jack: шаг 4, изображение 2 из 3 Huawei P9 Headphone Jack Replacement, Headphone Jack: шаг 4, изображение 3 из 3
    • Remove the water indicator on top of the screw.
    • Undo the two Phillips #00 screws.
    • Remove metal bracket (mind the adhesive underneath).
  5. Huawei P9 Headphone Jack Replacement: шаг 5, изображение 1 из 2 Huawei P9 Headphone Jack Replacement: шаг 5, изображение 2 из 2
    • Disconnect the flex cable and remove the headphone jack.
    • The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
Заключение
3 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
117 289 Репутация
Автор 188 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 521 руководств
Один комментарий
questo procedimento funziona anche con il modello p9 plus? grazie per l’attenzione
abcde181 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 5,912
