Huawei S10 Tablet USB Charge Port Replacement
Выберете то, что вам нужно
  1. Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: шаг 1, изображение 1 из 2 Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: шаг 1, изображение 2 из 2
    • Open the cover and press the SIM card and Micro SD card in to release them both.
    • Remove the screw under the hinge cover.
  2. Huawei S10 Tablet  USB Charge Port Replacement, Remove Back Cover: шаг 2, изображение 1 из 1
    • Use a prying tool to loosen the back cover from the display.
    • There are plastic clips holding the display and back cover together, but they come apart quite easily.
  3. Huawei S10 Tablet  USB Charge Port Replacement, Remover Display Cable: шаг 3, изображение 1 из 1
    • Carefully separate the display unit from the back cover, but not too far.
    • There is a cable connecting the two together.
    • Lift the ZIF Connector and remove the Display Cable.
    • Lay the display to one side.
  4. Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: шаг 4, изображение 1 из 2 Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: шаг 4, изображение 2 из 2
    • Flip the ZIF connector to loosen the flex cable for the USB charger port.
    • It is possible the cable is glued down, sliding a flat tip underneath should be enough to loosen it for removal.
    • Remove the two screws holding the charger port in place.
  5. Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: шаг 5, изображение 1 из 2 Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: шаг 5, изображение 2 из 2
    • Install the new charger port, Insert the cable in the ZIF connector and test to make sure it charges. Replace the screws for the USB Board
    • Insert the display into the back cover.
    • Replace the screw by the SIM card / Micro SD card slot.
    • Completed!
Заключение
2 участников успешно повторили данное руководство.
Harvey
Участник с: 02/15/16
5 214 Репутация
Автор 10 руководств
3 Комментариев
Is this charger available
Doyin Nwakanma - Ответить
Charger port for Huawei s10
My s10 is not charging,if i plug it will show as if it was going to charge but it won't so what do i do in this situation
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 2,913
