Выберете то, что вам нужно
To remove the band straps I follow this video:https://www.youtube.com/watch?v=1bqa1X2R...
The watch contains two parts, a metallic ring and the rest of the watch (grey part). You need to make the two parts turn in opposite directions until you see the part identified in the picture with the red rectangle. Then you can separate the two parts.
The only way I found to open the watch was to heat it up and open it with a flat screw driver. The result is sad but at least now we know what's inside.
2 участников успешно повторили данное руководство.
