Введение
This guide will show you how to replace the battery. The steps are very short and simple that everyone can change the battery.
Выберете то, что вам нужно
Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
Lift the battery with your finger up and out to remove the battery for replacement.
After the battery is removed, replace the battery
Make sure the battery sits correctly by locating the power output at the bottom left.
10 участников успешно повторили данное руководство.
