Введение
This guide is used for the replacement of a Huffy Kids Tricycle seat. A broken or damaged seat caused by either falling hard on the ground or being crushed accidentally, these guides would make replacement easy and faster. You would be needing just two tools to complete this guide.
Additional Information
- SKN(Stock Keeping Number): 62960
- ID: 34634A3E
- UPC (Universal Product Code): 2891429161
- Brand: Huffy Bicycle Company
- Manufacturing Number: 29161C
- Item Height: 9 inches
- Item Length: 3 inches
- Item Weight: 0.15 lbs
- Item Width: 3 inches
Выберете то, что вам нужно
Place the spanner on the bolt on the underside of the seat.
Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
Give the seat a wiggle to check that it is tight against the bracket.
If there is any play, tighten the screws a few more turns.
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
