Введение
Hydration backpacks are becoming increasingly popular across a wide range of demographics, from concert goers to hikers, these durable and handy water containers are perfect for taking along on rough terrains and crowded spaces. While their design is sturdy, rough use over time can cause scratches and leaks to make the bag less than optimal for use. In this guide, we show you how to repair it in such a way that you can get at least a few more years of use out of the backpack.
Выберете то, что вам нужно
Remove the hydration bladder from inside the backpack.
Seal the leak on the bladder with tenacious tape.
Smooth out all the edges and apply pressure for approximately one to two minutes.
Slide the heat shrink tube over the pipe and hold tightly in place over the ruptured area.
Using a hair dryer, apply heat to shrink the tube until it is tightly sealed in place.
Reinsert the pipe back into the bladder and twist lock it back into place as shown.
Slide the bladder itself back into backpack and pull the pipe out through the opening as indicated and your bag is good to go!
3 участников успешно повторили данное руководство.
