Введение
Is your massage gun not turning on? It probably means that the battery has reached the end of its usage. This is a guide will show you how to replace the battery of your Hyggly percussive massage gun.
Выберете то, что вам нужно
Using the Phillips #00 screwdriver, unscrew the 1 Phillips head screw underneath the power button.
Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws under the rubber stopper.
Twist and remove the circular black lid that houses the main circuit board.
Pull apart the main body of the massage gun. The gun should now be in three parts.
Detach the wires connected to the main circuit board.
Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws inside the main body of the massage gun.
Pry open the lid once the screws are removed.
Remove the top cover from battery compartment.
Remove the rubber sleeve off the battery compartment.
Remove the sticker off the bottom of the battery compartment near the power switch.
Using the Phillips #00 screwdriver, unscrew the 3 Phillips head screws around the power switch to access the inside of the battery compartment.
Remove the bottom lid of the battery compartment to reveal the second circuit board.
Detach the wires of the battery from the circuit board.
Еще один человек закончил это руководство.
