Введение
Pop filters help to minimize audio cutting out or loud popping noises. If your HyperX QuadCast S Microphone is experiencing these issues, you may need to replace your pop filter. The pop filter is located inside the microphone rather than on its exterior. The pop filter is secured by a layer of glue attached to a wire, so it is important to remember to apply glue to any replacement pop filter.
Set the microphone on a flat surface.
Pull each of the support bands upwards and off of the notches to release the microphone from its base.
Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
Once the Tap-To-Mute sensor has been removed, you will now have access to the pop filter.
The pop filter will be in a fixed position being glued to the wire. Remove glue residue before continuing to remove the pop filter.
Еще один человек закончил это руководство.
Один комментарий
"Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion."
This part is keyed. It literally cannot be pulled in any rotational motion...
