Введение
This guide will show you how to replace the broken/defective power switch for your Retron 3.
Выберете то, что вам нужно
In order to get into the system you're going to have to remove the 4 rubber boots on the bottom of the console in order to access 4 hidden screws underneath. The other two screws are already accessible.
You can barely see it but the upper shell is standing upright on the front right corner.
There are 11 screws that need to be removed in order to remove the entire PCB unit.
The AV/Power/NES PCB will be the last to remove during disassembly and first to replace during reassembly.
NES controller boards location.
This is where your defective switch and it's 6 pins would be located looking at it from a downward angle.
Once you've got the PCBs arranged in a way where they won't fall over you can begin to remove the switch. Either using a braid/pump/bridge the 6 pins that are soldered to the through holes of the main PCB and remove your defective on/off switch.
Once the mess, if present, is cleaned you can insert your replacement 8mmx8mm switch and solder the pins to the underside of the main PCB.
Once the soldering is complete then so is this repair. Simply reassemble your device and hit your power button and it should power up as if there was never a problem. If you can't keep the original consoles alive at least continue the great memories of your favorite 8-bit games. Happy Retro Gaming!
Еще один человек закончил это руководство.
