Hyundai Grand i10 Sportz Brake Light Bulb Replacement
Выберете то, что вам нужно
  1. Hyundai Grand i10 Sportz Brake Light Bulb Replacement, Brake Light Bulb: шаг 1, изображение 1 из 1
    • Visually inspect the brake lights to determine which bulb isn't functioning correctly.
  2. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 2, изображение 1 из 1
    • Access the back of the brake lights by opening the trunk of the car.
  3. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 3, изображение 1 из 1
    • Locate the cover directly behind the faulty brake light.
    • Use a screwdriver to twist the cover anti-clockwise, granting you access to the brake light compartment.
  4. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 4, изображение 1 из 1
    • Locate the black wire behind the cover.
  5. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 5, изображение 1 из 1
    • Trace the black wire within the compartment.
    • You'll find the twist-lock attachment point for the brake light bulb at the end of this wire.
  6. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 6, изображение 1 из 1
    • Gently twist the faulty bulb in an anti-clockwise direction to unlock it from its twist-lock mechanism.
    • Carefully pull it out from the socket.
    • Caution: Ensure you are properly grounded before touching the light socket. Static electricity may cause damage to the light or the socket.
  7. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 7, изображение 1 из 1
    • Acquire a replacement bulb.
    • For the 2018 Hyundai Grand i10 Sportz, you'd typically require a bulb of type P21/5W
  8. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 8, изображение 1 из 1
    • Insert the new bulb into the socket.
    • Rotate it clockwise to lock it securely in place.
  9. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 9, изображение 1 из 1
    • Insert the bulb with the socket back in place.
    • Caution: Make sure everything is locked in place.
  10. Hyundai Grand i10 Sportz Brake Light Bulb Replacement: шаг 10, изображение 1 из 1
    • Close the brake light compartment by twisting the cover clockwise using a screwdriver.
    • Test the brake lights to ensure they are working correctly.
Заключение
Congratulations on successfully replacing the brake light bulb on your 2018 Hyundai Grand i10 Sportz! Regular maintenance and timely replacements ensure the safety and longevity of your vehicle's lighting systems. Always test the functionality of any components after repairs to confirm everything is in working order. Drive safe!
Еще один человек закончил это руководство.
Jeron Dia
Участник с: 01/17/23
199 Репутация
1 руководство автора
Команда
York University, Team M-3, Allen Summer 2023 Участник York University, Team M-3, Allen Summer 2023
YORK-ALLEN-SU23SMG3
3 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 50
За всё время: 482
