This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Замена батареи IBM Thinkpad 600E
    • Переверните ноутбук низом вверх и найдите местоположение батареи.
    • Переключите рычаг с закрытого замка в открытый замок.
    • Вытащите батарею пальцами.
Заключение
Для установки новой батареи, повторите указанные шаги в обратном порядке.
4 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
en ru
42%
Maxat Alibayevпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Kevin Nguyen
Участник с: 10/04/16
722 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-4, Nance Fall 2016 Участник USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 членов
Автор 12 руководств
2 Комментариев
The IBM ThinkPad 600 battery uses six Panasonic Li-Ion cells in a 3Sx2P setup, and has a battery controller onboard the pack (under the lump covered by the IBM label). The problem has been that controller which limits the maximum energy output, especially if the pack is too hot. It has a fuse and a thermistor in between the cells. if the controller sees low voltages , the pack will be “open” yet the cells can still be good.
I have opened a pack manufactured in 1996 and the cells were good, such that I have recharged each cell pair directly. If you still have a ThinkPad 600 and several bad packs, open them carefully with a sharp blade along the plastic clamshell, remove the bottom, turn the pack with the label facing down, get a regulated Li-Ion cell charger, attach it carefully to the ends of each pair straps (the cells are welded together), and charge each pair until they have a minimum of 3.2 VDC each (or let it charge up to 4 VDC). Then tape the clamshell together and plug the pack in.
rayramirez - Ответить
I am trying to find a video of how to change CMOS battery on my IBM ThinkPad 600E
Martyn Hunter - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 39
За всё время: 1,978
