Введение
This guide will show you how to replace your keyboard. Sometimes the keys get broken or worn out, or the track point gets damaged, thus needing it to be replaced.
  1. Flip the laptop over and find the battery latch. Flip the laptop over and find the battery latch. Flip the laptop over and find the battery latch.
    • Flip the laptop over and find the battery latch.
  2. Move the latch to the side with the unlocked symbol.
    • Move the latch to the side with the unlocked symbol.
  3. Pry the battery out using your fingers. Pry the battery out using your fingers. Pry the battery out using your fingers.
    • Pry the battery out using your fingers.
  4. Use an antistatic wrist strap to avoid the risk of electric shock. Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover. It is easier to remove the coin screw using a thicker coin, such as a nickel.
    • Use an antistatic wrist strap to avoid the risk of electric shock.
    • Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
    • It is easier to remove the coin screw using a thicker coin, such as a nickel.
  5. Unlock the highlighted latch and pull the disk drive out. Remove the disk drive. Remove the disk drive.
    • Unlock the highlighted latch and pull the disk drive out.
    • Remove the disk drive.
  6. Most of the screws have a small, plastic covering attached with an adhesive. Use the metal spudger to pry it off. Make sure to note which screw came from which hole. Four 18mm long M2.5 screws Two 16mm long M2.5 screws
    • Most of the screws have a small, plastic covering attached with an adhesive. Use the metal spudger to pry it off. Make sure to note which screw came from which hole.
    • Four 18mm long M2.5 screws
    • Two 16mm long M2.5 screws
    • One 4.5mm long M2.5 screws
    • Four 3mm long M2.5 screws
  7. Open the laptop all the way until it is flat. Take the black circle off and remove the screw.
    • Open the laptop all the way until it is flat.
    • Take the black circle off and remove the screw.
  8. Pry the keyboard case up from the bottom and gently pry it up from all other edges. Use caution when opening the case, as there are two ribbon cables attached to the keyboard case. Use caution when opening the case, as there are two ribbon cables attached to the keyboard case.
    • Pry the keyboard case up from the bottom and gently pry it up from all other edges.
    • Use caution when opening the case, as there are two ribbon cables attached to the keyboard case.
  9. Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary. Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary. Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
    • Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
Заключение
Kevin Nguyen
Участник с: 04.10.2016
626 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-4, Nance Fall 2016 Member of USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 13
За всё время: 570
