IBM ThinkPad T41 Modem Replacement
Выберете то, что вам нужно
  1. IBM ThinkPad T41 Modem Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. IBM ThinkPad T41 Modem Replacement: шаг 2, изображение 1 из 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. IBM ThinkPad T41 Modem Replacement: шаг 3, изображение 1 из 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 Modem Replacement: шаг 4, изображение 1 из 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 Modem Replacement, Modem: шаг 5, изображение 1 из 1
    • Remove the three screws holding down the modem in the upper left corner of the laptop.
  6. IBM ThinkPad T41 Modem Replacement: шаг 6, изображение 1 из 1
    • Lift the modem up, unplugging it from the motherboard as you lift.
  7. IBM ThinkPad T41 Modem Replacement: шаг 7, изображение 1 из 2 IBM ThinkPad T41 Modem Replacement: шаг 7, изображение 2 из 2
    • Pull out the wire that connects the modem to the screen.
    • Unplug the other cable that attaches the modem to the motherboard
Заключение
Еще один человек закончил это руководство.
Marissa Blustein
Участник с: 04/16/10
543 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 7-8, Maness Spring 2010 Участник Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 членов
Автор 29 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 4,358
