Введение
This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its RAM.
Инструменты
Запчасти
Детали не указаны.
Close the screen and turn the closed laptop over.
Remove all 17 screws on the bottom of the computer.
The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
Turn the laptop right side up and open the screen.
Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
Remove the keyboard.
3 участников успешно повторили данное руководство.
Один комментарий
You only need to take out 4 screws on the bottom of the laptop that have a picture of a keyboard beside them to remove the keyboard. I don’t know why the tutorial says to take out all the screws. Other than that, great article.
