IBM ThinkPad T42 Display Replacement
Выберете то, что вам нужно
  1. IBM ThinkPad T42 Display Replacement, Bottom cover: шаг 1, изображение 1 из 1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Display Replacement, Rear screws: шаг 2, изображение 1 из 1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Display Replacement, Keyboard and Trackpad: шаг 3, изображение 1 из 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Display Replacement: шаг 4, изображение 1 из 2 IBM ThinkPad T42 Display Replacement: шаг 4, изображение 2 из 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Display Replacement, Bezel Removal: шаг 5, изображение 1 из 2 IBM ThinkPad T42 Display Replacement, Bezel Removal: шаг 5, изображение 2 из 2
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
  6. IBM ThinkPad T42 Display Replacement, Display Screws: шаг 6, изображение 1 из 1
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
  7. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: шаг 7, изображение 1 из 1
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
Заключение
6 человек успешно провели ремонт по этому руководству.
Austin Kidd
Участник с: 04/21/10
317 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 29-76, Johann Spring 2010 Участник Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 членов
Автор 37 руководств
2 Комментарии к руководству
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - Ответить
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 40
За всё время: 13,548
