Введение
Removal/repair of the display
Инструменты
Запчасти
Детали не указаны.
Unscrew the 2 Phillips screws on both sides of the T42's rear.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
Unscrew the screws holding down the display.
Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
4 участников успешно повторили данное руководство.
Комментариев: 2
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
