IBM ThinkPad T42 Fan Replacement
Выберете то, что вам нужно
  1. IBM ThinkPad T42 Fan Replacement, Bottom cover: шаг 1, изображение 1 из 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Fan Replacement, Rear screws: шаг 2, изображение 1 из 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - Ответить
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Ответить
  3. IBM ThinkPad T42 Fan Replacement, Keyboard and Trackpad: шаг 3, изображение 1 из 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Fan Replacement: шаг 4, изображение 1 из 2 IBM ThinkPad T42 Fan Replacement: шаг 4, изображение 2 из 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: шаг 5, изображение 1 из 2 IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: шаг 5, изображение 2 из 2
    • Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
  6. IBM ThinkPad T42 Fan Replacement, Lower Bracket: шаг 6, изображение 1 из 2 IBM ThinkPad T42 Fan Replacement, Lower Bracket: шаг 6, изображение 2 из 2
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Fan Replacement, Microphone cover: шаг 7, изображение 1 из 1
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Fan Replacement, Fan Removal: шаг 8, изображение 1 из 2 IBM ThinkPad T42 Fan Replacement, Fan Removal: шаг 8, изображение 2 из 2
    • Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
    • Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
    • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
Заключение
8 участников успешно повторили данное руководство.
Kevin Rehm
Участник с: 04/19/10
472 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 29-76, Johann Spring 2010 Участник Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 членов
Автор 35 руководств
2 Комментариев
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - Ответить
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
Tobyn Genn - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 27
За всё время: 26,242
