Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
8 участников успешно повторили данное руководство.
2 Комментариев
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
