Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The Mini-PCI port can be accessed easily after removing the rear cover
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Carefully disconnect it from the motherboard and pull it out of the device.
Еще один человек закончил это руководство.
