IBM ThinkPad T42 Wi-Fi Card Replacement
Выберете то, что вам нужно
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: шаг 1, изображение 1 из 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: шаг 2, изображение 1 из 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: шаг 3, изображение 1 из 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 4, изображение 1 из 2 IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 4, изображение 2 из 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: шаг 5, изображение 1 из 1
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 6, изображение 1 из 1
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 7, изображение 1 из 1
    • Carefully pull it out.
Заключение
3 участников успешно повторили данное руководство.
Kevin Rehm
Участник с: 04/19/10
472 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 29-76, Johann Spring 2010 Участник Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 членов
Автор 35 руководств
Один комментарий
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 13,734
