IBM ThinkPad T42 Wi-Fi Card Replacement
Выберете то, что вам нужно
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: шаг 1, изображение 1 из 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: шаг 2, изображение 1 из 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - Ответить
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Ответить
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: шаг 3, изображение 1 из 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 4, изображение 1 из 2 IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 4, изображение 2 из 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: шаг 5, изображение 1 из 1
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 6, изображение 1 из 1
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: шаг 7, изображение 1 из 1
    • Carefully pull it out.
Заключение
3 участников успешно повторили данное руководство.
Kevin Rehm
Участник с: 04/19/10
472 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 29-76, Johann Spring 2010 Участник Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 членов
Автор 35 руководств
Один комментарий
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 13,734
