IBM ThinkPad X41 Battery Replacement
  1. IBM ThinkPad X41 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn laptop over, make sure lid side is faced down.
  2. IBM ThinkPad X41 Battery Replacement: шаг 2, изображение 1 из 1
    • Locate battery release button lock on laptop, and press down.
  3. IBM ThinkPad X41 Battery Replacement: шаг 3, изображение 1 из 1
    • Hold laptop battery release button and gently pull battery away from laptop.
Заключение
Magaly Espinoza
Участник с: 09/12/16
183 Репутация
1 руководство автора
Команда
CSU Fullerton, Team 2-4, Bruce Fall 2016 Участник CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
4 членов
Автор 8 руководств
2 Комментариев
How can you open the battery case and replace the lithium ion cells?
Janie Godfrey - Ответить
This could be possible, but it's the hard way.
Open the battery case will be difficult, and you well need to keep the BMS circuit board inside the battery pack then build a battery pack with new cells and reactivate the BMS again as some battery BMS have a security that cut the power output when the BMS has stopped to be powered. So after replacing the cells, the battery might not work as is as the BMS might cut the power output of the battery pack.
I don't know if this battery pack has this kind of security on it's BMS.
Brendan -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 26
За всё время: 933
