Введение
This Guide shows the how to remove and replace the WiFi Card of this device.
Выберете то, что вам нужно
Start with the laptop with the side with the logo facing down.
Next you will have to remove all the screws in the red circles
Flip the laptop so that the logo is now facing up
locate the lock switch on the front right
Slide the switch to the right to unlock the laptop
Lift open the laptop
The keyboard should be detached from the bottom part of the laptop
Hold the edges of the keyboard and slowly pull up until it opens
Locate the two wires connected at the top of the WiFi-Card
Hold the card down and use the tweezers to pinch the plug and pull up.
Place fingers on the two clips holding the card in place
Pull the clips outwards until the the card pops up
Pull the card out by pulling out away from your body
To replace, follow these steps in reverse order
2 участников успешно повторили данное руководство.
2 Комментариев
I need to know what's role of the cables AUX and MAIN because i cut one
AUX and MAIN cables are antenna cables. In this laptop there are two antennas, MAIN and AUX.
If you have a soldering iron, simply solder the two parts of the cable you cut and everything is gonna be fine.
I also recommend using shrink tubing to isolate the soldered part.
Note : laptop can work without this câble, but WiFi speed and stability will suffer.
If you can't solder the câble or can't by a new one, you can try to use only main by pluggin the only remaining antena câble to MAIN and leaving AUX unlpuged.
Brendan -
