IBM Thinkpad T60 LCD Screen Replacement
Выберете то, что вам нужно
  1. IBM Thinkpad T60 LCD Screen Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 LCD Screen Replacement: шаг 2, изображение 1 из 2 IBM Thinkpad T60 LCD Screen Replacement: шаг 2, изображение 2 из 2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: шаг 3, изображение 1 из 3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: шаг 3, изображение 2 из 3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: шаг 3, изображение 3 из 3
    • Open the laptop so that the screen is facing you.
    • Use a plastic opening tool to pry off the eight plastic screw covers around the display.
    • Note that there are screw covers on the sides (two on the left and one on the right).
    About "Note that there are screw covers on the sides (two on the left and one on the right).":
    1. Are these screw covers glued?
    2. After finish replacing any parts, do I need apply glue to attach these screw covers again(or they are self-glued)?
    3. Is this method(screw covers cluing) very popularly used with IBM Thinkpads?
    (I need to replace Thinkpad X40 LCD rear cover, but not confident to start)
    Mike Yue - Ответить
  4. IBM Thinkpad T60 LCD Screen Replacement: шаг 4, изображение 1 из 1
    • Use a #0 Phillips screwdriver to remove the eight 3.25 mm screws uncapped from the previous step.
  5. IBM Thinkpad T60 LCD Screen Replacement: шаг 5, изображение 1 из 2 IBM Thinkpad T60 LCD Screen Replacement: шаг 5, изображение 2 из 2
    • Carefully pry the plastic border away from the screen using the plastic opening tool.
    • Note that this step requires some force. There are plastic clips that help hold the border in place so do not worry about snapping sounds.
    These plastic clips are very popularly used, must be very careful to use force.
    when you hear the "snapping sounds", you probably already broke the clips.
    Mike Yue - Ответить
  6. IBM Thinkpad T60 LCD Screen Replacement: шаг 6, изображение 1 из 1
    • Use your fingers to pry the screen out of its housing far enough to gain access to the ribbon cables and small screws holding the screen in place.
  7. IBM Thinkpad T60 LCD Screen Replacement: шаг 7, изображение 1 из 1
    • At the top of the screen, detach the small white clip by pulling it towards you with your finger.
  8. IBM Thinkpad T60 LCD Screen Replacement: шаг 8, изображение 1 из 2 IBM Thinkpad T60 LCD Screen Replacement: шаг 8, изображение 2 из 2
    • Using a #0 Phillips screwdriver, remove the 4 mm screw.
  9. IBM Thinkpad T60 LCD Screen Replacement: шаг 9, изображение 1 из 2 IBM Thinkpad T60 LCD Screen Replacement: шаг 9, изображение 2 из 2
    • Using a #0 Phillips screwdriver, remove the four 3.25 mm screws
    • The other two screws are in the same position on the opposite side of the display.
  10. IBM Thinkpad T60 LCD Screen Replacement: шаг 10, изображение 1 из 2 IBM Thinkpad T60 LCD Screen Replacement: шаг 10, изображение 2 из 2
    • The screen should be free to move now. Let the display rest on the keyboard with the screen facing down.
    • Peel the tape off to expose the LCD connection.
  11. IBM Thinkpad T60 LCD Screen Replacement: шаг 11, изображение 1 из 2 IBM Thinkpad T60 LCD Screen Replacement: шаг 11, изображение 2 из 2
    • Turn the inverter over to expose the white clip.
    • Squeeze and pull the wires with your fingers to detach the white clip.
  12. IBM Thinkpad T60 LCD Screen Replacement: шаг 12, изображение 1 из 1
    • Disconnect the video cable by pulling the grey flat wire. Now the screen is completely separate from the ThinkPad.
Заключение
5 участников успешно повторили данное руководство.
Cody Kratochvil
Участник с: 01/11/13
515 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 7-9, Maness Winter 2013 Участник Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 членов
Автор 16 руководств
Один комментарий
Thanks for the info! ☼
Stck Flw - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 14
За последние 30 дней: 40
За всё время: 12,349
