Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Always power down the computer before attempting any installation/removal of any hardware components. Be sure to remove the AC adapter and all cables from the computer. If the computer has been on, wait several minutes before beginning the procedure to ensure all parts have cooled down.
Выберете то, что вам нужно
Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
Use your finger to slide the tab to the right to unlock the battery.
Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
The battery is now disconnected.
Turn the computer back over, so the keyboard is facing upwards.
Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
Slightly lift the palm rest away from the computer.
Detach the connector by pulling upwards on the white tab.
5 участников успешно повторили данное руководство.
Один комментарий
Needs a tutorial on how to install it. I can’t get the palmrest on correctly, I can still lift up on the palmrest and the laptop doesn’t latch properly.
