Запчасти
Никакие детали не требуются.
  1. Turn the computer over so that the back is facing upwards.
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. Using a #0 Phillips screwdriver, remove the 17 mm screw.
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Carefully remove the plastic piece covering the hard drive by first pulling up then away  from the computer.
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  5. Locate the folded black tab within the hard drive port. With a screwdriver, pull the black tab out of the slot.
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  6. Pull gently on the black tab and the metal tray holding the hard drive will slide out. Pull gently on the black tab and the metal tray holding the hard drive will slide out.
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  7. Remove the plastic coverings on both sides of the hard drive.
    • Remove the plastic coverings on both sides of the hard drive.
      • Note that there is no hard drive in this picture but the process will remain the same.
Заключение
4 участников успешно повторили данное руководство.
Kyle
Участник с: 18.04.2013
305 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-58, Johann Spring 2013 Member of Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 2
За 7 дней: 18
За 30 дней: 67
За всё время: 3,488
