Запчасти
  1. Turn the computer over so that the back is facing upwards.
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. Using a #0 Phillips screwdriver, remove the 17 mm screw.
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. Carefully remove the plastic piece covering the hard drive by first pulling up then away  from the computer.
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  4. Locate the folded black tab within the hard drive port. With a screwdriver, pull the black tab out of the slot.
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  5. Pull gently on the black tab and the metal tray holding the hard drive will slide out. Pull gently on the black tab and the metal tray holding the hard drive will slide out.
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  6. Remove the plastic coverings on both sides of the hard drive.
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
Заключение
To reassemble your device, follow these instructions in reverse order. You will need to find something to use as a pull tab for the new drive. You can get a long piece of tape, and fold the end and stick the rest to the drive.
5 участников успешно повторили данное руководство.
Kyle
Участник с: 18.04.2013
377 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-58, Johann Spring 2013 Участник Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 12
За последние 30 дней: 35
За всё время: 5,043
