Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
Separate the trackpad with the bottom mouse buttons from the trackpad panel.
Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
Replace the trackpad panel.
Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
6 участников успешно повторили данное руководство.
