Введение
Follow these instructions to remove and replace a potentiometer on your guitar.
Выберете то, что вам нужно
Gently place the instrument upside-down on a soft surface.
Locate the battery cavity cap and screws.
Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
Gently lift the battery from the cavity.
Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
Use a Phillips #2 screwdriver to remove the four screws on the backplate.
Turn the instrument over.
Locate the potentiometer knob.
Locate the allen screw socket on the knob.
Use a 1/16" allen wrench to loosen the allen screw.
After the screw is loosened, lift the knob off of the instrument.
Locate the potentiometer nut, at the base of the potentiometer piston.
Use the adjustable wrench to remove the nut from the potentiometer.
Carefully turn the instrument over.
Remove the potentiometer from the instrument by gently pulling it upward.
Use the soldering iron to release the black, yellow, and white wires from the side of the potentiometer.
Use the soldering iron to release the black and green wires from the bottom of the potentiometer.
To reassemble your device, follow these instructions in reverse order with a new potentiometer.
Еще один человек закончил это руководство.
