Введение
The WiFi module is the primary method for wireless network connectivity. If this module shows symptoms of malfunction, a USB-to-Ethernet cable adapter can be used to maintain network access until the module is replaced.
Выберете то, что вам нужно
Insert a plastic opening tool in the seam between the keyboard and laptop body.
Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
Locate the ribbon cable connecting the keyboard to the motherboard.
Use the tip of the opening tool to lift the black flap on the connector.
With the twezers, gently lift the ribbon cable out of the connector.
Ensure the cutouts on the end of the cable match the tabs on the connector.
Locate and remove the screws holding the bezel to the laptop body:
Two 3 mm Phillips screws
Three 5.5 mm Phillips screws
Flip the laptop over.
Locate and remove the screws holding the bezel to the bottom panel:
Ten 4.5 mm Phillips screws
Locate the power board cable and disconnect it by pulling the cable head towards the front of the laptop.
Lift the keyboard bezel off the laptop. The bezel is secured to the chassis by 10 plastic clips around the circumference that can be released with the plastic pry tool.
Using the tweezers, remove the ribbon cable connecting the WiFi module to the motherboard.
Using the tweezers, lift up on the retaining tab of the module retention bracket and slide the bracket to the left, then lift it free.
10 участников успешно повторили данное руководство.
4 Комментариев
I need to replace the wifi card in one of these laptops and I’d like to get a different brand. What is this form factor called?
I have the same issue. Couldn’t find anything on the internet. My BT is defective, because it sometimes disables my mouse. This computer was a beautiful and well build, with the great touchscreen, but wireless connections are total mistake from the early beginning. The integrated wifi likes not to find any network. Since 2019 I’m working with the usb WiFi module bought on aliexpress. It is far better than the installed, but sticks out the chassis and took one port.
