Introduction
Only 15% of UK taps now use rubber washers. The rest use ceramic disc cartridges of which yours might literally be any of 5000 variations. It’s due to this complication that most plumbers advise you to throw it out and install new.
This guide shows you how to accurately identify yours so you can track down replacements rather than wasting, time, money & precious Earthy resources needlessly replacing something that can easily be repaired.
Parts
No parts specified.
Turn OFF hot and cold supplies.
Open lowest and highest taps to drain the whole system down.
Remove the tap head. Often held on with a hidden grub screw or with a screw under the indices (thing that's coloured blue or red or says hot or cold) on the handle at the end.
Remove the 'shroud'. Some pull off, some screw off, some need 'persuading' off!
Hold the tap body tight. You really do not want it to move because if it does it may cause the pipework connection underneath to leak.
The rule of thumb is that if your tap is connected via flexible pipes then it's less problematic if the tap body moves a tiny bit. If it's connected to solid pipes however, it's vital it does not move.
Remove the cartridge using the ring end of the 17mm combination spanner. Often cartridges are put in very tightly indeed & using an adjustable wrench or the open ended part of the spanner will not give enough purchase to break it free. All that happens is that you ruin the hex completely & can't then get it out. Short sharp shocks work well.
To get an exact replacement you'll need the following dimensions:
A - Number of splines (best way to get those is to take a clear image of the end of the spindle on your phone and then blow it up so you can count half of them and then just double the number. WRITE IT DOWN!
B - The spline diameter is vital. If you don't have a vernier gauge then wrap thread around it 10 times & cut the ends so they meet. Lay thread out straight (not stretched) & tape ends down. Measure its length & divide by 10 for spline dia. Typical are 7.6, 7.8, 8.0 etc. Don't be put off by what apparently odd numbers. WRITE IT DOWN!
C - Measure length of splines. WRITE IT DOWN!
D - Measure from top of splined shaft to underside of shoulder. WRITE IT DOWN!
E - Does the 'shroud' screw on? WRITE IT DOWN !
F - Measure from underside of 'shoulder' to end of metalwork. WRITE IT DOWN!
G - What size is your cartridge? 3/4" measures approx. 25mm across its base. 1/2" measures approx. 18mm across its base. WRITE IT DOWN!
