Выберете то, что вам нужно
Flip the device over so the bottom is facing up.
You will know it is the bottom because there will be six silver screws visible.
Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
Lift panel free of device.
Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
Flip the disk drive over so the the plug on the daughter board is visible.
Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Does anyone know if the MAC USB version works on modern PCs?
