Выберете то, что вам нужно
Flip the device over so the bottom is facing up.
You will know it is the bottom because there will be six silver screws visible.
Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
Lift panel free of device.
Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
Еще один человек закончил это руководство.
