Введение
This guide details the necessary steps to remove the front facing camera from the Leader Impression i7 tablet. Make sure you have a replacement camera ready before starting this guide.
Выберете то, что вам нужно
Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
Remove the transparent, orange tape from the edge of the battery.
Pry the battery off, using the plastic opening tool.
Pull the battery away from the adhesive.
Peel the gray tape from the top of the battery.
Lift the camera unit from its housing. The unit should come out with minimal force.
